2000 Chevy 3500 crewcab
Old 08-13-08, 09:22 AM
My truck shuts off while in idle and it sounds like the engine is going to die at any time. It has a little less than 300000 miles on it but its never been used for heavy construction. My sis's boyfriend says he thinks its something to do with the throttle body. Any idea?
Old 08-14-08, 10:29 AM
is the check engine lamp on? what engine is it running
computer should be scaned for codes
but as for the throtal bod could be dirty get some air intatke cleaner and clean throtal body also the idle motor could be removed and cleaned also egr valve could be stuck open how dose it run off idel while driving?
Old 08-15-08, 09:34 AM
2000 chevy 3500
In order to keep it from shutting off when i stop or switch from drive/reverse. I have to press the brake and the gas must idle at at least .5 RPMs. While driving, the motor spits and sputters the whole way. It feels like there is some kind of drag when I accelerate, or go uphill at all. I know its a gas hhhooggg to begin with, but its drinkin through gas like there's no tomorrow.
Old 08-15-08, 09:48 AM
2000 chevy 3500
its a 5.7 liter and the check engine light is always on.
Old 08-21-08, 06:56 AM
you have got to get the codes read so we can find out wher to start check engine lamp = electronic computor control problem eg bad sensors wiring adjustments
Old 09-13-08, 05:34 PM
shadetreeall's Avatar
truck mech
yes you do need the codes to fix this . sounds like air idle contol , throttle pos sensor or evan low fuel pre. if it use,s alot of fuel check vacume hose to pres regulator and see if it smels or has fuel in it. and thats the problem
Old 09-15-08, 06:47 PM
Jim-426's Avatar
Are you GROUNDED? No I mean the freakin truck..
Lifes not too Short;;Its that we're Dead for so Long
