1989 Ford Coachmen Motor Home
Old 08-13-08, 03:27 PM
Any good place to buy replacement brake lines? Took a look at
the lines and have decided to replace them. They sure have the lines in tight- any ideas on running the new brake lines would be appreciated. Thanks
Old 08-13-08, 04:00 PM
Your local automotive store should have them all ready to go, at various lengths. Figure out where your going to run them, and get your measuring tape out, or string, and measure the string after. The main thing I would worry about is to follow original path, but if it's easier to take a different route, make sure they are out of the way of debris flying up from roads. , any suspension parts that may rub or wear on them when bouncing up & down,and away from any hot areas close to exhaust. That's usually the reasons they are ran the way they are, (top side of axle housing, above frame rails etc) is to protect them from those type of things.
