rear brakes
Old 08-15-08, 01:18 PM
rear brakes
HI:
I changed my rear brake shoes and now I can't get the brake drums on, it's a Ford F150 pickup, any help here is much appreciated?
Old 08-15-08, 01:32 PM
Gunguy45's Avatar
Super Moderator
Have you adjusted the star wheel all the way down? I know, prob a dumb question.
BTW may want to post the year as well, for the mechanics on here.
And always the possibility of the wrong shoes.
Old 08-15-08, 03:15 PM
Happened to me; adjust the adjusters all the way in and it should go on; might need to wiggle shoes and the drum a bit with a little push on the drum.
Old 08-15-08, 05:06 PM
Unclediezel's Avatar
Make sure the E-Brake cables arent hung up.. It will hold the shoes out away from the cylinders, and cause what your describing....
Take the "Crossbars" out and try to fit the drums...if they fit with the bars removed...the cables are binding.
Old 08-17-08, 12:23 PM
I did thxs though, it's still won't go on even if I hammer it in.
By "crossbars" do you mean parking brake hold down spring???
if the cables are binding does that mean I have to change it, much thanks for the info.
Old 08-17-08, 12:26 PM
Ford 1988 F150, not the wrong shoes though thxs.
Old 08-17-08, 03:17 PM
Look at the brake cyls. and see if they are all the way retracted, also check to see if the top of the shoes are touching each other. If not move them outward a Little they may be hanging up there.
