Toyota
Old 02-22-09, 03:07 AM
Question Toyota
I have a toyota pickup, 1985, R22, 4X4.The turn signals work in the rear but not in the front, I have checked fuses, flasher, bulbs, all good. Any suggestions?
Old 02-24-09, 03:59 AM
B
would probably test the switch you can usually access the wiring at the base of the steering column to see if you are getting power through the switch since you have eleiminated most of the components except the switch and wiring might also check the bulb sockets.
