Bearing Seals 2000 Ford F150
Old 03-01-09, 09:29 AM
C
Has anyone done this?
need to replace seals on rear axel bearings, leaking grease into drum.
1- How long?
2- Any special tools?
3- How much does this normally worth for a shop to do?
have done this on a BMW 325E but not a truck.. is it about the same?
Old 03-02-09, 07:15 AM
mr_franksmith's Avatar
Greetings
I believe you need a press. Most Fords have the bearings pressed onto the axle shaft.
Old 03-02-09, 05:57 PM
G
no press is needed. The rear end cover has to come off and the pin that holds the spider gears has to come out so that you can get the c-clip that holds the axle in off then slide the axle out and remove the seal.probably a good half, 3/4 day job for the un-experienced. a shop probably charges 1 1/2 hour plus parts.
good luck
