2000 gmc sierra brakes
hello i have a 2000 gmc sierra and i cant get the caliper bolts loose for nothin. i have used pb blaster and air tools but nothing seems to work. any advice. thanks
david
david
Are you working on the caliper retaining bolts or the caliper bracket bolts? I am sure the caliper bracket bolts have threadlocker on them, and the caliper bolts may also have it on them, some heat on the bolts will loosen the locking compound. Apply the heat to the area where the bolt threads into the bracket or spindle. Only takes about 500 degrees to get threadlocker to let go, so you do not need to heat to glowing red, heat a little, try to remove and so on.
