Update 89 suburban choking out
Old 03-21-09, 05:59 PM
G
OK, changed fuel filter,replaced some cracked vacuum lines.
Still choking out. But does not choke out if I put it in reverse and gunn it. It spins the tires and just goes like a bat outa hell.
NO choking out in reverse. What is going on here?
Old 03-21-09, 07:54 PM
W
Again check wire harness between engine and firewall, engine torque may be causing an open circuit. When in reverse the engine torques in the opposite direction and may not open a bad spot in a wire.
