1996 dodge ram 1500 stall and not start
Old 03-23-09, 11:43 AM
K
my truck recently stalled while driving about 30 mph. it was maybe 3 minutes after it started. Now cranks but won't start. Had codes 12,31 and 45. I disconnected battery and all codes are off now. Exchanged ASD and a/c relays, checked wiring and hoses only visually, cranks solid just will not start. both battery terminals were rather lose, i could twist by hand and the previously not working radio now works. Any ideas. thanks
Old 03-24-09, 06:23 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Did you correct the problems indicated by the codes? They are there to tell you what is wrong with the truck. Clearing them erased any chance of your knowing without chance. I assume by only having one battery it is a gasser, right? Is your fuel pump energizing when you turn the switch to the on position? You should be able to hear it run for a second or two.
