removal of door handle and window crank 1995 chevy 30
Old 04-19-09, 07:37 AM
E
Hi,
How to you remove the manual door handle and window crank on the interior front passenger side door of a 1995 chevy G30 cargo van. I would like to remove the access panel to repair the bottom of the door that has rusted away.
Thank You
Old 04-19-09, 11:42 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Not sure of the cargo van, but Chevy mostly uses a modified "C" type clip over the spline shaft. If you push back on the door interior you should be able to see the clip on the shaft. It will take a hook like tool to remove it. You can buy the removal and installation tool at most parts houses...not expensive, but it gives you a way to put the clip back on which is a bear without it.
