1987 K-5 Blazer
Old 04-26-09, 05:23 PM
1987 K-5 Blazer
Hello all, I haven't posted here in a while. I still have my K-5 and it's giving me a bit of a fit.
When I hit the brakes, sometimes it develops a horrible wobble. Is it a warped rotor?
It doesn't wobble too bad going down the road, just when I hit the brakes. This started recently.
Thanks in advance.
1987 K-5 Blazer 4WD
Old 04-26-09, 06:46 PM
chandler's Avatar
Received 2 Votes on 2 Posts
Does sound like a warped rotor. Could have happened with the brakes hot and driving immediately into a water puddle. Most local shops can tell if it is warped without having to do alot of tear down.
Old 04-26-09, 06:53 PM
Gunguy45's Avatar
Super Moderator
Hmmm..gotta disagree..if it "wobbles" at all w/o the brakes applied, its not the rotors. I'd check rims and tires..then steering componants.
Warped rotors normally will "thump thump" and you will feel it in the pedal.
No mechanic..just an opinion.
Old 04-26-09, 06:54 PM
Thank you chandler. I do most of my own mechanic work, so I will probably tear it down this week and check it out. I did want a second opinion though.
Thanks Gunguy45, good point.
Old 05-08-09, 08:36 PM
Thank you for the advice. I replaced the front brake pads, turned the rotors, replaced the O2 sensor, and added a new steering stabilizer. Good as new.
Old 05-08-09, 08:46 PM
the_tow_guy's Avatar
Received 37 Votes on 29 Posts
I was going to add to check the wheel bearings, too, but you're obviously past that.
Old 05-10-09, 06:04 PM
chandler's Avatar
TG, I was going by what he said about hitting the brakes and it wobbling (vibrating). I had one and felt the vibration slightly even with the brakes released, I guess since the pads are so close to the rotor.
Old 05-13-09, 08:41 PM
Good call, I failed to mention that I replaced the inside bearings as well. They were trashed.
Old 05-18-09, 09:43 PM
Good Lord, why is a fuel pump assembly so damn high for this truck??? 200 bucks?
Yes, the fuel pump went out, luckily next to my driveway.
