GMC pkup spare tire won't lower
Old 04-29-09, 05:41 AM
daswede's Avatar
Because of neglect,my spare tire is stuck up and won't lower.
Cable cranks down o.k.
Anybody have a fix for this?
Thanks
Old 04-29-09, 05:45 AM
chandler's Avatar
Received 6 Votes on 6 Posts
Not sure, but I had a spare stuck to the undercoating on the truck. Guess it was put up too soon. You say you can get the cable to lower but the tire won't? Try prying it. out of the hole.
Old 04-29-09, 05:52 AM
Received 330 Votes on 293 Posts
You also might try whacking the perimeter with a rubber mallet - be carefull so the tire doesn't fall on you
Old 04-29-09, 08:09 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Just saw this exact problem in a magazine..Family Handyman? Yep, just checked, May issue pg 92.
Old 04-29-09, 04:26 PM
W
possible that the safety retainer is stuck. read your owners manual to learn how to get it to release.
Old 04-29-09, 06:50 PM
daswede's Avatar
I just had mine done today! I had a flat and was out of luck on trying to change the flat.
Garage yanked,pryed,sprayed a penetrating oil between the inside tire rim, and the bracket that actually holds the tire up
in place.
It came down,yay!!!
Mechanic said that the tire should not snugged up tight.
Just tight enough so that the tire has some slight movement. Supposedly this prevents crud from forming.
I,too neglected to lower and raise the tire occasionally.
Old 04-29-09, 06:58 PM
Gunguy45's Avatar
Super Moderator
According to the article in the mag. Spray with a corrosion preventative or coat everything with marine grease.
