Bleeding Boat Trailer Brakes
Received 41 Upvotes
I had to replace the brake drums & wheel cylinders on my boat trailer now I can't seem to be able to get the lines & cylinders bled. The actuator is a Model 10 by Dico, if that's any help.
Check out your local auto parts house for a vacuum bleeder. Some use a hand operated vacuum pump and pull the air and fluid out thru the bleeder valves rather than trying to push it through from the master cylinder.
