1984 chevy pickup 350 sputters when taking off
Old 05-23-09, 06:14 PM
Question 1984 chevy pickup 350 sputters when taking off
350 engine. I have changed spark plugs and wires, distributor, module, rotary, gas filter with no help. Engine lacks power when starting off but runs good after getting up to speed. Just sputters like a tractor at low speeds and runs rough. Any help would be appreciated.
Old 05-24-09, 03:06 PM
the_tow_guy's Avatar
Is that carbureted or fuel injected?
Old 05-27-09, 07:42 AM
carbuator. Think it may be the carb?
Old 06-02-09, 07:41 AM
sputters taking off
Possible causes, Acc pump in carb, vac leak, heat riser stuck.
Old 06-02-09, 08:10 AM
Gunguy45's Avatar
Super Moderator
I was thinking accelerator pump as well...if its just when you are accelerating...if it does it at constant low speeds..then one of the other things.
Should be pretty easy to check IIRC, just pop the air cleaner...work the throttle and look for a squirt of fuel in the throat. You'll need to hold the butterfly/choke plate open.
At least thats the way I used to check mine...course that was about 20 yrs ago last I had a carb on a vehicle.
How does it do if you "feather" the throttle when taking off?
