Tail Lights-Travel Trailer
Old 06-09-09, 06:58 AM
I continue to have a problem with one of the bulbs on my travel trailer tail lights. The bulb connection corrodes and the bulb stops working. I can scrape the bulb connections and it works until it gets wet and corrodes again. Is there a fix for this?
Old 06-09-09, 08:04 AM
First step would be to find out where moisture is entering the tail light housing. Then seal the entry point(s) and replace any gaskets. Give the socket and contacts a good cleaning and then apply a thin coat of silicone grease to the socket, contacts, and bulb base. This should either cure or greatly reduce your lighting problem.
Old 06-09-09, 10:22 AM
Tail Lights
Goldstar,
Thanks for your help.
Ken
Old 06-09-09, 03:08 PM
chandler's Avatar
Ken, give up and go led. I did that on my jobsite trailer, and on my headache rack on the work truck. I know they are expensive, but worry free, basically.
Old 06-10-09, 05:21 AM
Lights
Thanks, Larry. Great idea!
