Explorer Hood Issue
Explorer Hood Issue
I have a 2000 Ford Explorer. The hood has been getting hard to open for some time. It was to point that one had to lean on the hood while another pulled the inside release. Now the hood will not release at all. Are there any tricks or what method would one use to repair or adjust this problem. This first happened at a Qwik Lube and the boys there could not get the hood up. Thanks, networker
You may be able to pop it from under the vehicle by reaching up. That trick works on 80's Volvo's not sure if it would help you but figured it may possibly help.
