wiring diagram
Old 08-29-09, 01:15 PM
bikernut's Avatar
wiring diagram
looking for printable wiring diagrams for a 1986 & 1987 Chevy/GMC 1500-3500 Pickup Truck
Old 08-30-09, 08:41 AM
chandler's Avatar
Welcome to the forums! Not sure if this will help, but you can do it for $4 on this site Wirediagram.com - 1987_CHEVROLET_C1500_ 2DR EXT CAB PICKUPwire information / technical wiring diagrams for autostart/alarm installation
But you can buy a Haynes manual that will cover the model year with a full diagram in the back of the book.
Old 08-30-09, 10:41 AM
bikernut's Avatar
I have the Hayes manual but it doesn't show the dual tank set up just the tank on the left side and I also have a Chilton Manual and it doesn't have the diagram either.
Old 08-30-09, 02:11 PM
chandler's Avatar
Not sure, but wasn't the second tank aftermarket? If so, it won't be in the diagrams.
Old 08-30-09, 04:08 PM
bikernut's Avatar
the dual tanks were an option and the little factory sticker in the glove box confirms this as well as the axle ratio, radio etc that are on the vehicle
Old 08-30-09, 08:11 PM
Speedwrench's Avatar
check also at your local library, ours has mitchel manuals on microfilm and you can make copys for .25 cents each page.
Old 08-31-09, 02:42 AM
bikernut's Avatar
good idea Speedwrench but there is a slight problem with that as my local library is a 2 room building and I doubt if they even know what I was talking about if I were to ask and this town is so small it is only open a few hours a week and they have to pipe in the sunlight to them. I will if I happen to go to the state capital and do as you suggested thanks.
Old 08-31-09, 04:56 AM
chandler's Avatar
What are you looking for as far as the wiring goes? We may can find it out for you.
Old 08-31-09, 04:55 PM
bikernut's Avatar
I need the 1987 Chevy/GMC truck 1500-3500 light duty wiring schematic for the dual fuel tank system from the dash switch all the way to the dual tanks including the selector valve to the tank with the in tank electric fuel pumps, 1986 didn't have TBI so it had the pump mounted on the engine and wired all different. thanks
