trailer tow outlet for 96 dodge ram
Old 09-04-09, 01:37 PM
trailer tow outlet for 06 dodge ram
the electrical plug for trailer tow is not working on the left side for brake and left turn signal. the tail lights work and all on the right side. the fuses are all good. the brake and stop on the truck itself are separate bulbs. is there a converter box or something that would make the plug not get current? I have all lights working on the truck but in the two trailer plug outlets both have no brake or turn signal.
Last edited by arizonaelkhunt; 09-04-09 at 01:54 PM. Reason: had wrong year of truck
Old 09-05-09, 03:04 PM
Unclediezel's Avatar
Look carefully at the fuses again....there are fuses for both left and right sides, as well as a "Trailer Tow" relay in the PDC...
If not, Remove the left rear tail light lens and find the waterlogged splice....
Old 09-06-09, 03:49 PM
follow up
thanks, but what is a PDC? I will check the fuses again. I was using a digital tester that when grounded and the tip placed on top of the fuse, it registers the voltage. I will pull them out and check them.
