turn signals both flash on trailer
When I turn on the left turn signal on my trailer, the right turn signal will also flash and vice versa if I turn on the right signal. Is this a grounding problem? I need a place to start - any ideas?
Thanks
Thanks
Not a grounding problem as both are working. Is this a new installation? If the tow vehicle has separate turn and stop lights , and the trailer has combination stop and turn in the same bulb - as most do, either you need a converter or your present converter has gone bad. These are available at most auto parts stores and any place that sells trailers.
Only other thought, and maybe your first check, is to see that the turn signal wires are not touching each other with a worn insulation spot shorting the two together.
Sorry to disagree but it could very well be the grounds.
I have found on more than one trailer that the ground causes this problem.
Check that each light has a ground wire at the bulb and also the trailer frame. Dont rely on the mounting bolts to make the ground connection. They rust there very quickly. Run a seperate wire to the trailer frame. Also it helps to run an extra wire from the trailer to the truck frame. Use a waterproof connector to allow this new wire to be disconnected when you disconnect the trailer plug.
Relying on the hitch ball for proper ground can cause problems as grease does not conduct very well.
The turn signal could have only one good ground at the trailer lights and therefore has to use both bulbs to complete the circuit.
Each light does have one ground to the light fixture but not directly to the frame. Do you mean run a ground from each bulb to the frame also?
Thanks for the help
Thanks for the help
so, did it just start doing this after working right for 23 years?
Goldstar has a very good point about the separate turn signals and tail lights on a vehicle and combined units on a trailer. Does this describe your vehicle and trailer or not? I causes a lot of frustration if this is applicable and the connections are not made using the proper connections and devices.
not sure what badeyeben is speaking about with the trailer ball as a ground connection. There should be a ground connection in your plug set. I will agree that the ground connections need to be made good if they are corroded though.
a bad ground can cause all sorts of odd lighting problems.
Thanks
Most auto parts stores that sell trailer hitches and balls will also sell the 3 to 2 converter.
It basically has separate wires that hook to your right turn signal feed, as well as to the left turn signal and to the brake feed in the car or truck. It has output wires for the left and right lights on the trailer. Some also have a feed hookup for the running/license light.
I don't know what triggers your trailer brakes, but the sending mechanism could have been left on a prior vehicle and not transferred to your current vehicle. A place that sells or rents trailers could help you with that.
so it must be a grounding problem
