bleeding clutch slave cylinder
Old 11-21-09, 07:23 PM
how to bleed clutch slave cylinder ,at home
Old 11-22-09, 05:05 AM
chandler's Avatar
Welcome to the forums!! Similar to bleeding brakes. Attach a hose to the bleed nipple and set it in a jar partially filled with new brake fluid. Top up the master cylinder. Slightly unscrew the bleed valve. Have someone pump the clutch once. Top up the master. Release the clutch. Repeat slowly keeping an eye on the level of the master cylinder. It is smaller than the brake reservoir so it will deplete quickly. Once all the air is purged, tighten the bleed valve, remove the hose, properly dispose of the brake fluid (or seal it up for future use), clean all areas of brake fluid and you should have an active clutch.
Someone will surely point out something I missed, as I went through this in my head, which doesn't hold as much RAM as it used to.
Old 11-22-09, 11:40 AM
clutch bleeding
Thank you.Great info.I will give it a try.
