towing with bumper
Old 01-17-10, 11:54 AM
R
towing with bumper
Hello Guys. I have a 2002 gmc Sonoma 4x4 with a step tow bumper. I am planning on getting a boat off a friend and would like to know if instead of installing a frame hitch maybe i could just put a ball on my bumper or install a step hitch. The boat is very light and small (plastic) and the trailer is a tee nee. The bumper i have is attached to the frame similar to the way a frame hitch would be installed. I have read where people don't trust tow bumpers but why did the factory put them on if you can't use them. I doubt that the combined weight of the trailer and the boat exceeds 600lbs and my bumper is rated for 3500. I'm not arguing i just want to know if I'm safe. Thanks.
Old 01-17-10, 11:59 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
If you are talking about one of those really light plastic row boats or even one of those small 2 seater power boats or a jonboat type thing...I think you'll be fine. I highly recommend taking it to a scale somewhere and actually checking the total weight and the tongue weight when fully loaded...no reason to try to guess.
I towed plenty of trailers full of mulch and topsoil (prob way heavier than 600 lbs) with my Dakota and only had a factory bumper and ball on it.
Old 01-24-10, 06:00 AM
R
Received 1 Vote on 1 Post
tow with bumper
I agree you will be OK I have towed small travel trailers with a bumper hitch. Check the bolts that hold it to the frame they work loose sometimes,but this happens when you tow things without springs.
Old 01-24-10, 08:14 AM
GregH's Avatar
Super Moderator
Received 37 Votes on 35 Posts
I agree that you should be able to tow what you propose to buy with a bumper mounted ball.
A downside though is that there is a good chance the trailer will not ride level which it should, especially if the trailer has 8" wheels.
An alternative to just bolting on a ball is a receiver that you bolt to the underside of the bumper.
This way you will have some flexibility in adjusting the trailer.
Click image:
Image courtesy of northerntool.com
