Dodge Dakota a/c problem
Old 06-01-10, 01:34 PM
Question Dodge Dakota a/c problem
Help! My a/c on my 92 Dakota is leaking water under the dash. I was told the drain tube is stopped up. My question is where is the drain tube and how do I UNstop it......?
Old 06-01-10, 08:35 PM
hmm-im not a dodge guy.
But the evap case drain is normaly about at the 'passengers' floor borad 'toe' level.
look under the vehc/ pull the pass side inner fenner linner back
& look for a thumb sized rubber hose /tube
try-( if possible) put a wet/dry vac on the fitting.
or just blow air into the fitting.
hope this helps!!
Old 06-03-10, 11:45 AM
NEsportsfan's Avatar
If the AC isn't critical for you, get another serpentine belt, but for the one without AC and 2 inches longer. A friend of mine did that when his AC compressor pulley froze on his 99 Dakota.
