transmission bushings
Old 10-04-10, 07:31 AM
D
Is it possible to change gm th350c automatic transmission bushings with out buying one of those expensive tools?
If yes can you give me a little on how to do it.
I am rebuilding it and hate to buy a bunch of tools for a one time deal.
dick2256
Old 10-07-10, 08:28 PM
hopkinsr2's Avatar
Im thinking if you took the bushing & the housing to you r local transmission place, They would be glad to press them in for you.. Roger
Old 10-08-10, 02:07 PM
ASE MASTER's Avatar
dick2256,
You don’t offer a description, nor do you go into any specifics about the bushings you are trying to install. With all due respect to you, that is like saying; “My Address Is Number One Georgia”. Below is a list of bushings that must be installed with special tools. (Setting and proper seating is critical). If the bushing you are trying to install is not on this list, then specialized tools are not necessary.
Front Pump Body - Babbitt
Stator Support - Front - .485 Wide
Stator Support - Front - L/U - .655 Wide
Stator Support - Rear
Direct Clutch Drum - Bronze
Direct Clutch Drum - Babbitt
Direct Clutch Drum - Solid H.D. - w/o Groove
Direct Clutch Drum - Wide - Babbitt - w/Oil Groove
Input Ring Gear
Sun Gear To Output Shaft & Reaction Carrier
Output Shaft Pilot
Output Shaft Pilot - Long - Bronze (3)
Output Shaft Pilot - Teflon
Case To Output Shaft - Babbitt
Case To Output Shaft - Bronze
Extension Housing - Bronze
Extension Housing - Babbitt
Extension Housing - Teflon
Governor Bore Repair Bushing must be installed with tool T-0107
