Installing a solar panel to charge a truck battery
Old 10-22-10, 08:51 AM
I would like to know how the install a solar battery charger in a ford f250 6 litre diesel
Old 10-22-10, 03:21 PM
GregH's Avatar
Super Moderator
Welcome to our forums!
Connect positive to positive and negative to negative!
No really.
What are you asking?
Do you have one and want to hook it up?
Old 10-22-10, 08:54 PM
hopkinsr2's Avatar
Greg is right,, Positive to positive,, Negetive to negetive,,, Do you have issues with the batteries?? I've seen these things start @-35* without any boost or block heaters if they have good batteries... If you have starting problems, let us know & we'll get you dialed in.... Roger
Old 10-23-10, 04:41 AM
If you haven't purchased one yet, please keep in mind to check amperage output of panel before you do. A lot of people are misled by what it will do for them. Roughly, a 15 watt panel, on a very clear, sunny day, will be lucky to produce 1 amp of current/hr. So if your thinking it will work as a battery charger, save your money, it will trickle charge at best, on a sunny day. Check reviews at this link for Canadian tire. $140 for a panel that is basically useless. ( Sunforce Solar Panel, 15 Watt | Canadian Tire ) Seen guys install bigger ones on roof of trailers for camping, and are lucky to get enough amperage to keep fridge running on gas, and maybe play stereo, and a light or 2 before it starts draining the battery down. Honestly, another battery and an isolator may be a better choice, depending on what it is your trying to accomplish in the end.
