No heat
Old 10-31-10, 05:38 PM
No heat
My heater in my truck just blows cold air. How do I find out what the problem is so I know what to fix
Old 11-01-10, 05:10 AM
Received 330 Votes on 293 Posts
Welcome to the forums Sopheia09!
Does the engine get warm? [temperature at gauge]
Old 11-01-10, 06:11 AM
the_tow_guy's Avatar
Received 57 Votes on 47 Posts
Moved you to a fresh thread.
Old 11-01-10, 03:23 PM
P
Received 681 Votes on 628 Posts
What is your vehicle make, model and year?
When you move the temperature control do you hear anything under the dash moving?
Is this sudden or has the problem been getting worse over time?
The hot engine coolant travels by hoses to a small radiator (heater core) located under the dash, usually on the passenger side below the glove box. A fan blows air through the heater core. Most vehicles have a door that blends outside cool air with the hot air to give you warm. This door or the mechanism that controls it can get stuck in the cold position causing you to have only cold air but basically any part in the system could cause your problem.
Old 11-01-10, 06:44 PM
H
If an older vehicle, you may have a plugged heater core or a stuck thermostat.
First and foremost, make sure that you have enough coolant in the radiator.
