Compressor failure
Old 12-14-10, 08:30 PM
C
Compressor failure
Hello! I have a coach (Isuzu) which uses an air brake system.
Recently, the air compressor failed and the lubricating oil (engine oil) leaked to the compression chamber. The large amount of oil finally gone through the air dryer, via brake hoses reaching various valves.
Is there any negative effect of the oil on the brake hoses / valves? Is it necessary to replace the valves / brake hoses?
Thanks.
Old 12-14-10, 09:12 PM
ukrbyk's Avatar
Received 12 Votes on 9 Posts
they have special RV section here, you might have better luck there.
Old 12-15-10, 05:09 AM
the_tow_guy's Avatar
Received 57 Votes on 47 Posts
Moved you to the RV section.
