how do i identify which transmission i have
Old 02-16-11, 08:24 AM
O
Red face how do i identify which transmission i have
I have a dodge ram 2500 diesel with 4 speed automatic transmission. I need to know if its a 47re or a 47rh. Is that a code on the id pad: the numbers on the drivers side of the transmission case are 52118 158215734 1 a5 b3.....build date 09/28/99......it is a 2000 yr model.....thanks to any dodge experts that know.....or anyone else...thanks again
Old 02-16-11, 01:48 PM
chandler's Avatar
Received 6 Votes on 6 Posts
Is yours a 12 valve or 24 valve? If 12 valve, I believe it is the RH, while the 24 valve has the RE. Yours is a "second generation" vehicle, which should be a 24 valve.
Old 02-16-11, 05:29 PM
O
yes you are correct, its a 24 valve. I cannot find this info anywhere on the transmission, and i need to know to adjust the the bands to the right specs. thanks for your help..
