Chevy LUV PROBLEM!!!!! HELP PLEASE!!!!!!
Old 05-06-11, 06:51 PM
A
I have a 1981 Chevy Luv The motor is from a 1979 Luv, I installed a New 1981 Luv Distributor also a brand new coil. I wired then according to the manual but no matter what I do I cant get a Spark, my power Wire goes to the coil, ground wire to the red wire on the distributor, white wire from distributor to ground. new coil, new distributor, new pickup coil, new cap and rotor. and I cant get spark anywhere. Any information would be appreciated.
Old 05-07-11, 05:13 AM
the_tow_guy's Avatar
Received 68 Votes on 57 Posts
I'm guessing this is a points & condensor distributor? Couple of dumb questions probably:
1. The distributor is rotating?
2. The points are properly adjusted?
Other than that I would be double checking the circuit for a bad connection, either voltage to the coil or an open somewhere in the distributor/ground circuit. Coil could be dead, of course, but that's probably less likely.
Old 05-07-11, 08:52 AM
A
ill repeat
the 79 motor was points but but in 81 chevy luv went to hei which is the only difference between the 2 engines i just bought a brand new and installed an HEI distributor into the 79 motor which is in my 81 body. in reference to ur questions yes the distributor is turning and and as far as voltage goes i am running 12 volts to the coil from the ignition the from what i understand the ground from the coil goes to the distributor, distributor to ground if someone knows a different way for it to be wired or knows more about i wld luv to hear it btw ty tow guy for your input i appreciate the chance to rattle the rocks in my brain
Old 05-07-11, 09:47 AM
W
Received 36 Votes on 33 Posts
Spark
Why would you ground the distributor? You want the spark to get to the spark plugs.
Old 05-10-11, 07:37 PM
A
I tried everything Else but got no spark at all Do you know of a way to Wire it that would help???
Old 05-11-11, 05:50 AM
I think you've missed something in the circuitry. I don't think you can just drop an HEI into the engine and connect the wires, but I've never tried that so maybe....
Wirepuller, the reference to grounding was to what an ignition circuit used to look like; the positive terminal on the coil would be 12 volts and the negative terminal ran to the distributor (points) to do the open and close thing and fire the coil. I don't know that an HEI doesn't maybe require some minor change in circuitry to work. Hopefully we'll get some help on the subject.
When I'm out and about today, I'll ask around for opinions from the mechanics.
