2000 dodge dakota trans problem
Old 07-23-11, 05:50 PM
I just replaced the transmission pan on it now it wont go into gear. It has a 4.7 with 4wd. Pan was rusted an begining to seep. I put a new filter in to fill it with ATF+4 now it wont go into gear an check engine light came on . It only has 62000 on it. Iam suppose to go back to work in PA tomorrow, need help quick. Thanks!!
Old 07-24-11, 12:53 PM
the_tow_guy's Avatar
Sounds like you've knocked something loose during the tranny service, either under the pan or externally. Also check your transfer case selector depending on how it's operated. Couple of times I've towed "no movement" 4wd vehicles in to a tranny shop and the mechanics found the transfer case partially out of gear.
