Norcold will not cool
Old 09-01-11, 06:32 AM
Unhappy Norcold will not cool
My Norcold has the "n" on the fridge, which means it is not cooling. I checked the manual and it says "1st time-Before reset" check.....I did check all the suggestions, everything seems okay. My question is, is there an actual RESET switch? I can not find anything in the manual stating a reset switch. Our RV is a Jayco Ambient 2004. Thanks
Old 09-02-11, 11:46 PM
First reset is done by simply shutting the fridge off, then back on again. This should allow it to start it's own diagnostic and repair and should run normally again. If code re-appears and fridge not cooling again, it must be taken to an RV service center for a hardwire reset on control board. There is a certain set of steps that must be performed by a technician.
