Wiper Problems
Old 10-13-11, 09:23 AM
djayha1's Avatar
Question Wiper Problems
I have a 1982 Chevy Silverado (C-10) PU. The other day turned on the wipers, they worked fine, ten min.s later shut them off went into store, started back home, No wipers, would not do N Ething ..... Attempted to straight wire the motor and nothing, figured that the motor burnt out. Replaced the wiper motor,cranked the truck, turned on the wipers everything is lovely, Til i turned them off, They kept going, switch was not responding, disconnected the wiper switch, Cranked truck, wipers werew still going , Had to disconnect the motor to get them to stop! It's not the motor, Not the switch! Where could the problem be?
Old 10-13-11, 09:45 AM
Received 294 Votes on 261 Posts
You might have the motor [or switch] wired wrong.
Old 10-13-11, 09:55 AM
djayha1's Avatar
Wiper problems
Don't think so! After all they just plug in! Besides they were not wired wrong when they first started to act up. Thanks anyway!
Old 10-13-11, 10:03 AM
The switch is supposed to interrupt the power flow. You need to figure out why power is going to the motor when the switch is turned off.
Old 10-13-11, 10:13 AM
djayha1's Avatar
Wiper problems
That IS the problem and I'm aware of that !
Old 10-13-11, 11:00 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
Don't these have some sort of switch in the wiper gearbox to "park the wipers? Or is that actually a part of the motor assy?
If that was bad on the new one, then once energized it would prob just keep running.
Was it a new motor assy or a junkyard part?
Old 10-13-11, 12:13 PM
chandler's Avatar
Received 5 Votes on 5 Posts
In addition, not sure about your model, but on my 1993, the wiper assembly had a replaceable "chip" for lack of a better word. I had the same problem with mine and replacing that component fixed it. I'll see if I can come up with the part name.
Old 10-13-11, 06:08 PM
B
Received 1 Vote on 1 Post
Chevy Wipers Are Not Made To Work In Rain
Your family truckster is a little older than mine (89 K-1500) but they can make you pull your hair out. The wipers along with the instrument cluster (cluster is right) have electrical problems.
I go in the car wash and after turning them on they won't shut off. Today, driving in a light mist, I'd turn them on for one swipe. After a while they wouldn't shut off for about 20 seconds then they'd stop straight up and down. After turning the truck off they did go back to normal....them things are possessed.
Old 10-14-11, 07:02 AM
R
Chev trucks have had a ton of problems with bad solder joints on the circuit boards of wipers. Go to fullsize chevy . com I beleive they have a sticky on this.
Old 10-14-11, 09:35 AM
B
WIPER MOTOR
PULSE/CIRCUIT
BOARD
Should be able to buy one at a parts store.
Old 10-15-11, 08:42 AM
djayha1's Avatar
Wiper problems
Will try, Hope these hints work! Don't have much hair left to pull out
THANK YOU !
