1993 f 150 turn signals not working
Received 0 Votes
I found and replaced the under dash fuse. The old one looked fine but I had a new one and replaced it. The emer. flashers work as do all other lights. All other functions on the blinker switch work fine. The lamps don't light at all (rather than coming on but not blinking). I would appreciate some help.
I'd check the turn signal relay. Can you hear a click, click, click when the flashers are on, but not the turns? That would be the relays making (or not making) the noise. Even if you get a click with the turns, the contacts could be shot.
Normally the emergency flasher and turn signal flasher can be swapped to verify operation. Autozone.com can show you what the flashers look like and if they are the same. Normally they are in or near the fuse box.
Received 0 Votes
Thanks. My little mind figured that if the relay was not working then the lights would come on and just not blink. Replaced it and it is fixed. The emer. flasher relay fit but would not fix it. Thanks again. Rg
