Fuse size for lights
Old 12-26-11, 03:39 PM
T
This may not be the correct forum but figured it wouldn't hurt to ask... Installing some headlights & and a work light on an old tractor & need to know what size fuse would be correct to install in the circuit for protection. The headlights are 55 watt each (12VDC) so that's a total 110 watt load & the work light is just 35 watts.
Thanks
TexasFire
Old 12-26-11, 06:23 PM
R
Received 1 Vote on 1 Post
Take the total wattage and divide by the voltage this will give you the amperage the lights will draw.
Old 12-26-11, 08:03 PM
chandler's Avatar
Received 6 Votes on 6 Posts
I would opt for a breaker rather than a fuse. I'd rather have them flash a few times on the way back to the barn than to blow a fuse and have to drive in total darkness.
Old 12-27-11, 08:39 AM
T
Thanks guys.... I used that formula & rounding up a tad I plan to use a 5 amp fuse for the 35 watt work light & a 10 amp fuse for the headlights. Still trying to decide if I want to bother with light relays or just wire directly to the battery. The switches I bought are both rated at 20 amps & are lighted so its not like I'm going to be leaving the lights on. I would go with a breaker but my ranch is only a whopping 5 acres so I don't have too far to go!!!
TexasFire
Old 12-28-11, 09:43 AM
E
You didn't mention your wire size and fuse and wire size goes together and both then must support the load requirements. Are you going with something like a 16AWG stranded wire?
Old 12-29-11, 02:50 PM
R
On a 5 acre ranch I would reccomend a kerosine lantern.
