Help ! 99 E-150 4.2 waterpump part question
Received 0 Votes
O.K. here goes , I have a steel pipe coming from the water pump then splits into 3 lines connected to three hoses one of which is the heater core.Can anyone identify this part by name ? It 's leaking slightly [coolant] at a rusted section and figure it is about to break. Is this a part I can get online or will I need to go to the dealer ? Any info would be greatly appreciated .Thanks
I've not seen a manifold like you describe coming off a water pump. The E150 pump has a hose inlet, but the impeller and waterways are sealed to the engine boss via bolts and gasket. Is there any way you can take a picture of this and post it for us to see? I may not be thinking of things correctly.http://www.doityourself.com/forum/el...your-post.html
