intermittint no start
Old 04-13-12, 10:11 PM
2000 E 150 Iv'e had this no crank a few times over the last 5 months. If I turn the key on and jump the sol. on the starter it starts. I found the wire that was cut for the alarm installed at the dealer. When it cranks the starter wire to and from the alarm have 12v. When it don't crank no power from keysw to alarm and alarm to starter. How tuff is it to change the keysw. with cruise control,tilt wheel. Thanks.
Old 04-20-12, 11:51 AM
not to hard at all. disconnect bat. turn key to run position. on bottom of column cover find 4 holes. 3 have screws 1 has a pin you need to push in and slide out switch. reverse order to install.
Old 06-02-12, 10:38 AM
Thanks for the reply. Now I think I have another problem. I think it might be the trans. gear position sensor/ neutrel sw. Do these things act up at 54, 000 miles. I have 12v going out of the alarm and key sw. and intermittant starts at times. more often now. thanks for any help.
