1980 Chev. C 30 350
Old 05-26-12, 01:00 PM
Question 1980 Chev. C 30 350
Having a problem with no spsrk from HEI dist. Replaced all internal parts including coil. Have 12 V on primary wire.Not even the slightest sign of spark. Anyone alse ever have this problem
Old 05-26-12, 01:27 PM
Are you saying that you replaced the ignition module already? Normally if all else is good around rotor, cap and wiring, this is the next think to consider. The module does the work of what used to be done with points etc.
