2000 Silverado 1500 2WD turn signal issue
Old 07-11-12, 05:51 PM
5.3L V8, my right turn signal flashes at double the speed of the left turn signal. I first suspected the bulb was out, however, the bulb was still operative and flashing at the same speed as the indicator in the dash. I tried replacing the bulb with several other bulbs, getting the same result. The fuses all look good. What's next?
Old 07-12-12, 02:50 PM
Flasher relay is a possibility if all of your turn indicator bulbs/filaments both front and rear are working properly. Do your hazard flashers work as normal? Some GM's share the hazard and turn indicator flasher also, therefore I ask.
Old 07-23-12, 05:44 PM
Check all of the flasher bulbs on the vehicle.
