Mazda B2300 Problem. Please Help!
I have a 1993 Mazda B2300 five speed, The truck will not even crank (turn over), I have ruled out starter, battery, and altinator. Can anyone please tell me where else to look? I also changed out the ignition switch in the steering column.
Have you checked to see if you're getting 12v to the small wire on the starter solenoid while the key is turned to the crank position? Have you checked to see if the clutch safety switch is working properly?
Mike
Mike
