2 " receiver Question
Old 09-30-12, 08:58 AM
Question 2 " receiver Question
any one have any experience, or an opinion, as to Whether or Not
the "Cushioned" Receiver ball mounts are worth the $75 investment ?
thanks
mike
Old 09-30-12, 10:23 AM
chandler's Avatar
Cushioned with what? If it is cushioned, it probably has a weak spot that I wouldn't want following me at 75 mph. Got any examples? I've never used one.
Old 09-30-12, 10:54 AM
Gunguy45's Avatar
Super Moderator
2nd one down.....Ball Mounts - Hidden Hitch
Basically some very stiff polyurethane bushings, sorta like those used on aftermarket suspensions. I notice this brand only goes up to 10Klbs, so no joy for bigger load haulers.
Old 09-30-12, 11:04 AM
chandler's Avatar
I don't know, sounds comparable to the "o" ring for the Challenger. Too much play will eventually wear out the ends of the oblong hole it would seem. At 10K# I would go with goose neck or 5th wheel anyway.
Old 09-30-12, 05:05 PM
GregH's Avatar
Super Moderator
I wouldn't wast money on that.
The reason you would need that in the first place is because of the normally sloppy fit of the hitch in the receiver.
I think there will still be movement of the hitch.
I take a strip of appropriately sized metal and tap it on one side and the top of the receiver after I install the hitch.
Leave it stick out in inch or so then bend it around the receiver.
It makes the hitch rock solid and vice grips will pull it out.
Old 09-30-12, 06:46 PM
guess I could have given a better description of what I am looking at.
i think Gunguy may have seen it ?
the hitch pin hole is elongated.
with the round hitch pin hole mounted in the polyeurathane bushing
1.Amazon has it as
Convert-A-Ball AM-S-C-2 10-1/4X3/4X2 Cushioned Ball Mount
Buy new:$70.25 $57.95
8 new from $57.95
I am going to be pulling a small camp trailer ( 2,500 lb GTW- 250 lb TW weight)
Old 10-01-12, 05:16 AM
I've got one on my truck but with an 8'000 pound diesel it's hard to detect if it's helping or not. I bought it because at the time it was the only hitch with a high enough weight rating. If I had a choice though I would not spend extra money for the cushioning. The amount of travel it can move is pretty small and you are talking about a truck and trailer that each weigh thousands of pounds. So, I'm sure the cushioning helps some tiny bit but how much can it really do?
Old 10-01-12, 06:33 AM
OK,
Thanks for the reply's
I'll just keep my money
Old 10-01-12, 07:28 AM
If you are a farmer pulling grain carts and wagons with no suspension under them this is a good hitch. If your unit has springs it is not needed.
