Exhaust Mating Surface gap Sealing ideas?
Old 10-06-12, 10:08 PM
99 5.7L Silverado
The converter mates to the muffler with 3 bolts and of course the gasket
However, the converter mating surface looks warped
And when the Converter/ muffler are bolted together, You can actually wiggle the gasket around in the warped area
how could you seal this area??
tin- wouldnt there be a heat issue
Permatex high temp silicone-wouldn't there be a heat issue as well
***edit
slice of bread- we know that will not work
replacement converters- too costly ~$390 after tax
Old 10-07-12, 07:43 PM
I would get out the grinder and flatten the warped surface. As for sealers furnace cement might work or JB Weld.
