Help ! 99 E-150 no electric
Received 0 Votes
My 99 e-150 is electrically dead. Battery does checkout fine but no 12 volts getting anywhere. This one is a tough one. Where to start with troubleshooting etc.......Anyone able to help ?
No voltage ANYWHERE? Check the ground cable from the battery all the way along it's length and connections to body/frame/engine. Follow hot lead to fuse box and check for voltage.
Not sure if these have a fusible link in the hot line....but I'd check that as well. Also main fuse/breaker.....might be about 100A...should be shown on the fuse block diagram. If either of those blew...you probably have a bigger issue.
