So I've got a 93 Dodge dakota 5.2L 4x4
Old 01-09-13, 02:27 PM
T
I'm hearing some metalic grinding noies coming from front and back passenger side.
basically when I'm driving as I hit the gas initially you'll hear it and it will go away as I speed up, but when I let my foot off the gas to coast it kinda raps on clunks abit and when I press back on the the gas it grinds until I hit a certain speed.
I'm thinking wheel bearing for the front but as fro the sound coming from the back... U Joint?
Old 01-09-13, 07:31 PM
iceman681's Avatar
Received 5 Votes on 4 Posts
my guess would be a trans or motor mount. under load or negitive load is causeing it hit/rub some where.
Old 01-14-13, 08:00 PM
T
Foreign object caught in the brake drum? I once had a return spring break, and it made some funny noises until I found it.
If one of the wheel bearings is bad, honestly I'd check 'em all, and probably change the differential fluid.
