Gas mileage
Old 02-03-13, 04:26 PM
D
dam
dam is offline
Gas mileage
Is there a difference in fuel mileage between mid grade and regular?
Old 02-03-13, 04:39 PM
chandler's Avatar
Received 9 Votes on 8 Posts
Probably no gas mileage difference, but performance difference. It will depend on what your car's manufacturer stipulates is the best fuel for your car that is important. Changing grades can, at best, waste money, and at worst damage emission systems.
Old 02-03-13, 05:15 PM
T
Octane rating essentially provides a guide as to how much compression a given fuel can handle before the compression leads to premature detonation or pinging, which can cause engine damage. The higher the octane rating, the higher compression the engine can be without pinging.
Many modern engines have a device called a knock sensor, that will allow some modern fuel-injected vehicles to attempt to reduce or eliminate premature detonation by controlling spark or fuel delivery. When an engine detects excessive knocking or pinging it will reduce performance to reduce the pinging. That can possibly translate into fuel economy losses too, but not necessarily.
One should generally run the lowest octane that one's engine can use without pinging, which is what the manufacturer specifies when they sell the vehicle new. If your owner's manual says that it's just fine to use 87, then use 87. If it says 89 or 91 perferred but that 87 is acceptable in some circumstances if higher isn't available, then probably run whatever is preferred.
The use of higher-than-necessary octane fuel provides no benefit. The engine isn't going to run more or less efficiently because of a different octane rating, one is only going to spend more money.
Old 02-04-13, 06:18 AM
N
Received 20 Votes on 18 Posts
T-W-X pretty much covered everything.
The simplistic answer is... If it's fuel injected, it should have a knock sensor. If it has one, run the recommended Octane rated fuel. The computer with that sensor will adjust things to prevent problems.
Keep in mind, if your vehicle is rated for a high octane, running a lower octane level can do affect your milage and potentially cause pre-mature engine wear.
Old 02-04-13, 06:36 AM
Received 1,165 Votes on 1,123 Posts
There is an optimal octane rating for your car. Higher performance cars with higher compression in the cylinders will require higher octane and often will have performance and fuel economy degradation if lower octane fuel is used.
That said, my ex-wife had a 92 Honda Prelude when I met her and it became my car at one point - I noticed the sticker on the fuel door that said premium fuel was required so I thought I'd try some (we'd been only ever putting regular fuel in it) - my mileage got worse, so I quit that experiment after two tanks.
Old 02-04-13, 09:51 AM
chandler's Avatar
Back when I was in college I had a '62 VW. Ran great. I thought I would "clean" the upper engine by running a tank of then Amoco White Gas. I think the octane rating was like 96+%. Finished that tank and noticed the tailpipes had fallen off Didn't do that again!! Too hot, I guess.
Old 02-04-13, 01:22 PM
Received 674 Votes on 597 Posts
Larry, I used to burn a tank full of white gas once a month - It did burn hotter but it kept all the key components clean! Unless I'm mistaken it was 100 octane. It was called white gas because it didn't have any lead added - if you can remember, leaded gas had a red tint.
Old 02-04-13, 04:28 PM
chandler's Avatar
You're right, I do think it was 100 octane. Clear as moonshine.......I guess.........never..........well I heard..........
Old 02-05-13, 04:54 AM
N
You guys where running what we call Ava gas (aviation fuel, now about 110 Octane).
Runs hot and stinks when racing 2-strokes.
Old 02-05-13, 12:04 PM
Used to have a neighbor with a hot rod he raced - had the compression up so so high that to go any higher would mean he'd have to move from gas to alcohol. You couldn't stand within 10' of the garage if that thing was running, the fumes would make your eyes water.
Old 02-05-13, 01:50 PM
chandler's Avatar
Yeah, but it was available at your corner Amoco station back then. The cars we built back in the 60's had such compression that it was needed. Just wish kids nowadays had just a taste of the power we produced from stock (and modified) engines, with only 2 years of highschool under our belts at the time. Times gone by.
Old 02-08-13, 11:16 AM
T
We once ran some low-lead airplane fuel in our Honda Fourtrax ATVs... Yeah, they ran hotter, but they did run faster...
Higher thermal coefficient of expansion means that the expanding, burning fuel pushes harder against the piston. More vroom.
To my knowledge, regular automotive fuel won't really differ that way.
