thermostat will not open
Old 02-04-13, 08:16 PM
on my 89 chevy truck the thermostat will not open to let the water flow . it is a new thermostat and will open when placed in a pan of boiling water on the stove
Old 02-04-13, 08:34 PM
iceman681's Avatar
Received 3 Votes on 3 Posts
my guess is an air pocket. you will have to blead it out. with out coolant around the the t-stat it will not work right. also why do you think the water is not flowing?
Old 02-04-13, 08:40 PM
Received 2 Votes on 2 Posts
Does there happen to be a small nut on top of the thermostat housing? If so, that is the bleeder.
Old 02-04-13, 09:38 PM
top radiator hose not getting hot.it get hot only after i release the pressure out of the system
Old 02-05-13, 06:58 AM
I put a block heater on one time and it wouldn't circulate till I replaced the rad cap.
Old 02-05-13, 07:43 PM
iceman681's Avatar
are you sure the truck is reaching the temp needed to open the t-stat? and does the heater hoses get hot? both?
Old 02-05-13, 09:22 PM
Are you sure the thermostat is installed correctly? If installed backward it wont open.
Mike
Old 02-13-13, 06:58 AM
Your engine head and block should be placed according to the specifications. Otherwise, water pressure will continue to build up and thermostat valve will never open at its own. Try to check your head, block and genuine head gas kit, before you change more thermostat valves. After doing this, I am sure you will never get this heat problem again.
