1984 ford f250
Old 03-10-13, 07:51 PM
T
1984 ford f250
Carburetor issues, the car will run when you dump fuel straight into the carburetor but won't start or run any other time. Any idea what the issue or fix could be?
Old 03-10-13, 08:01 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
Sounds like the "carburetor" isn't getting fuel. Remove the fuel line and crank. No fuel coming out? Probably the fuel pump.
Old 03-10-13, 08:08 PM
Received 2,955 Votes on 2,666 Posts
Welcome to the forums.
I looked online and they show an electric pump or an old style mechanical pump could be used in your vehicle.
Do you have an electric fuel pump in that vehicle ?
If you do.......with everything quiet.....turn the key on and listen for it.
Old 03-10-13, 09:40 PM
T
I haven't tried the other stuff yet but somebody told me this "Clogged jet, needle set too lean, idle set too low, could be a lotta things. Start by turning up the idle screw and work from there. Most likely it needs a solvent bath and a professional tune." Does any of that seem worth trying?
Old 03-10-13, 10:09 PM
XSleeper's Avatar
Don't screw with the carb settings. Try the things mentioned 1st. It's quite simple.
Old 03-11-13, 05:27 AM
Received 672 Votes on 595 Posts
Have you checked/replaced the fuel filter?
Old 03-11-13, 05:45 AM
A
Received 72 Votes on 65 Posts
You might check the owner's manual to see if this is applicable or not, but certain mid-late 80's Fords, at least some of the F250's I know, had a switch that would shut off the fuel pump in the event of a rear end collision. Hmmm, had never given it much thought, but probably a post-Pinto thing, so maybe all Fords? Anyway, again, intended for rear end collisions, but I remember hearing of several instances where they shut off from rather insignificant events, such as hitching a trailer or someone jumping on the back bumper. It seems to me that the reset may be above above the passenger side kick panel, sort of behind the glove compartment.
Old 03-11-13, 07:37 AM
the_tow_guy's Avatar
Received 145 Votes on 113 Posts
Correct, many Fords & Mercurys do. On the F-series pickups the reset button is usually behind the passenger side kick panel. Feel for a notch on the upper edge, if there's one there reach finger over back of panel and you'll feel the button. This is only for in-tank electric pumps, of course.
Old 03-12-13, 04:25 AM
A
Tony,
The process of elimination must be applied here so that your issue can be resolved.
Let's start with something very easy, basic and fundamental.
Using a "Fuel Pressure Gauge" post the fuel pressure (PSI) that is reaching the carburetor.
Thank You
Amy
