vacuum problem
Old 03-29-13, 06:31 PM
vacuum problem
I have a 1982 c-10 with 4.1L and i need to know what the 5 vacuum ports on the right side of the carb go to.
Old 03-29-13, 07:54 PM
hopkinsr2's Avatar
If the vacuum decal isn't still on the fan shroud, (or under the hood somewhere), I think I've heard Autozone has stuff like this.. Check it out.. Roger
Old 03-29-13, 08:10 PM
I have the catalyst but it is not real clear on exactly which ports are which it only shows 3 on the cat but i have 4 or 5. I tried all the auto parts places and my old chiltons manual but no luck
Old 03-30-13, 09:37 AM
the_tow_guy's Avatar
Received 153 Votes on 118 Posts
Old 03-30-13, 11:41 AM
Is it stamped on the carb witch ports are D C B like it shows on the cat.
Old 04-13-13, 06:56 AM
vacuum problem solved. went to pull a part about a week ago and lucked up and found a 250 6cl like mine. bought the carb off the motor for 30.00 bucks and it was just like mine. and if you can read very small writing you can see each vacuum port is labeled like the catalyst shows. could have pulled my own carb to see this but i have learned with old trucks you make a big problem trying to solve a small one. thanks for the suggestions and help the auto zone page was a big help to.
