2001 Silverado 2500HD- NO REAR BRAKES
Old 04-08-13, 07:08 AM
Contaminated brake fluid, so changed master cylinder, hydro-boost brake booster, rear calipers, rear pads. Bled brakes starting with furtherest(r-rear). Had no rear brakes, no brake pedal and pedal returns slowly. Drove truck and rebled brakes. Still no brakes on rear and no brake pedal.
Old 04-08-13, 08:11 AM
Stuck proportioning valve?
Old 04-08-13, 08:58 AM
the_tow_guy's Avatar
New master cylinder bled prior to installation?
Old 04-08-13, 09:20 PM
did you replace the flex hoses as well because they can collapse and cause that
problem
Old 04-11-13, 05:28 AM
yes, Master cylinder was bled before installing.
Old 04-11-13, 05:32 AM
in the case of a stuck proportioning valve, does it have to be replaced?
Old 04-12-13, 02:41 AM
Hello everyone hows u ?
m new on this forum site and just want to share some information with you here m telling you about that how to increase your mobile signal at your home and your office just use the mobile signal booster,and the mobile antenna ,datacard antenna ,wi-fi booster,wireless router, and some of telecom products like the rf antenna ,and the wifi booster it really works just click here to know more
Pantagone Satellite, Mobile Signal Booster,GSM Mobile Signal Booster,Mobile Repeater, Mobile Amplifier,CDMA Booster,3G Mobile Booster, Mobile Antenna, Data Card Antenna, GSM Antenna, GPS Antenna, Wi-Fi Antenna
