1994 ford explorer
Old 05-10-13, 12:36 AM
I
1994 ford explorer
i can not roll the explorer backwards even if it is in nuetral it will roll forward this is a 4x4
Old 05-10-13, 03:03 AM
A
imadummy,
Iíve seen this issue on both the M5OD-R1 manual transmission, and the A4LD automatic transmission. With that being said, which transmission is in your Explorer?
Thank You
Amy
Old 05-10-13, 04:41 AM
I
geez im sry its an automatic A4LD 4.0 V6
Old 05-10-13, 07:35 PM
iceman681's Avatar
Received 5 Votes on 4 Posts
start jacking up wheel by wheel and find out where the issue is.
Old 05-11-13, 04:22 AM
A
imadummy,
Your no reverse could be an issue within the valve body where the plug behind the kick down is out of position. If the valve body gasket gets brittle and breaks, this will cause a loss of pressure to the reverse servo. If there is seal failure at the reverse servo, the servo will lose pressure and will no longer be able press the rear band. Then there is always the possibility that the rear band has broken, or is out of place and can no longer squeeze. All this is addressed in a TSB (Technical Service Bulletin) via a dealer. I would post the TSB for you, but I lost it (along with many other files) when my hard drive crashed.
Thank You
Amy
Old 05-15-13, 05:22 AM
I
ok ty for the info
i know this to be true this will be the last explorer i ever work on
