RV fridge...
Old 07-28-13, 12:52 PM
E
RV fridge...
Hi, I have a 2000 RV with a Norcold 1200LRIM and my temperature indicator leds have start to blink one after the other in a regular rythym and I can't stop them. The fridge is still cool but I can't set it for temp. From what I've read it is in BOS mode. I did follow the diagnostic guide and checked my thermistor but it is in the normal range. What else to do? should I reset the board?
Old 07-29-13, 02:30 AM
Received 723 Votes on 678 Posts
Welcome to the forums.
You checked the thermistor resistance and it checked within specs. based on temperature ?
Did you check the plug for corrosion ?
You can try a Power board reset to see if it comes out of backup operation.
