brake light stays on
Old 09-07-13, 06:44 AM
Question brake light stays on
I have a 2007 f150 and I can not get the brake light to go out. the e-brake is not sticking, fluid level is fine. I disconnected the low fluid sensor and the e-brake switch and the light is still on. if I play with the switch wire I can get it to go out but then it will flash on and off then stay on. any suggestions?
Old 09-07-13, 08:20 AM
Is it the rear brakes lights that are staying on, or the brake light on the dash?
Old 09-08-13, 06:48 PM
it's the dash light any ideas?
Old 10-02-13, 07:19 PM
canuk's Avatar
Sounds like you discovered where the problem lies. You just have to determine if it's at the wire connection to the switch or the switch or the alignment of the switch to the e-brake lever.
