Problems with trailer lights.
Hello, I know others have posted problems with trailer lights but could not find anything like my problem. So here go's i bought a trailer the wiring needed to be completely replaced, So i looked up the plug first which is a 6 pin round plug. Then i looked up a trailer wiring diagram and it said to run green and brown wire down right side of trailer. Then run brown wire and Yellow wire down left side of trailer. Hook white wire up for ground. So this is how i wired it up and i have running lights, brake lights, and when the running lights are on i have both right and left blinkers. How ever when i turn off the running lights and turn on the right side blinker both sides blink anyone have any idea whats causing this.
[TABLE]
[TR]
[TD="colspan: 3, align: center"]
[/TR]
[TR]
[TD="align: center"]Terminal Marking[/TD]
[TD="align: center"]Wire Color[/TD]
[TD]Function
[/TD]
[/TR]
[TR]
[TD]GD[/TD]
[TD]White[/TD]
[TD]Ground[/TD]
[/TR]
[TR]
[TD]TM[/TD]
[TD]Brown[/TD]
[TD]Running Lights[/TD]
[/TR]
[TR]
[TD]LT[/TD]
[TD]Yellow[/TD]
[TD]Left turn/brake light
[/TD]
[/TR]
[TR]
[TD]ST[/TD]
[TD]Blue[/TD]
[TD]Brake Control
[/TD]
[/TR]
[TR]
[TD]RT[/TD]
[TD]Green[/TD]
[TD]Right turn/brake light
[/TD]
[/TR]
[TR]
[TD]A (Aux)[/TD]
[TD]Black[/TD]
[TD]Power
[/TD]
[/TR]
[/TABLE]
Welcome to the forums.
Is that the color code you followed ?
You should have the two browns connected on the TM terminal.
Also double check the actual ground on the trailer frame. A poor ground causes a multitude of problems.
[TR]
ASME Wiring Color Code
[/TD][/TR]
[TR]
[TD]Function
[/TD]
[/TR]
[TR]
[TD]GD[/TD]
[TD]White[/TD]
[TD]Ground[/TD]
[/TR]
[TR]
[TD]TM[/TD]
[TD]Brown[/TD]
[/TR]
[TR]
[TD]LT[/TD]
[TD]Yellow[/TD]
[/TD]
[/TR]
[TR]
[TD]ST[/TD]
[TD]Blue[/TD]
[TD]Brake Control
[/TD]
[/TR]
[TR]
[TD]RT[/TD]
[TD]Green[/TD]
[/TD]
[/TR]
[TR]
[TD]A (Aux)[/TD]
[TD]Black[/TD]
[TD]Power
[/TD]
[/TR]
[/TABLE]
Yep thats the color code i followed, and everything works fine except for the right blinker with the lights off. Thats when both sides blink. I will check the ground again, i cleaned a spot and put a new terminal on it. Does each light need a ground? It only has 2 wires per light red and black. I figured the lights are grounded to the trailer by the bolts that hold the lights to the trailer? Do i need to run a ground wire to each light some how?
You shouldn't need to run a ground to each light. Make sure where the lights bolt on that they are making a good connection to the trailer.
